Check Engine light and rough idling
Hello,
I have a 2002 X-Type 2.5 and recently I have been having some problems. When I start the car in not very cold weather it idles pretty rough (at about 500 rpm) and the check engine light is on. Fortunately when the car warms up a bit the rough idling goes away but the check engine light stays on. I have searched the forums and found that the IMT O-rings may be the cause. I have ordered them and I should receive them in a few days. The car also has he new hose, the ribbed one. And just wondering if the O-rings don't fix it, what else should I try?
OK, so I replace the IMT O-rings. The old, yellow ones even cracked when I tried to get them out. Anyway the new ones are in. But that hasn't changed anything, except the fact that the check engine light is now gone. When I start the car in the morning the car still idles pretty rough, and there car also seems to misfire a bit, the check engine light flashes and the comp. says "Cruise not available". It also misfires when accelerating, I was going down the road when it misfired a few times and then it got back to normal and the check engine light disappears.
Also, I have changed the plugs a few months ago. I think then next thing I should do is change the coils. Anyways, I think I should first take it to my local shop to check for any error codes.
Thanks.
Thanks.
BrentGardner
28
04-26-2024 03:08 AM
