Chicago Anyone?
Chicago Anyone?
Does anyone from chicago know a good, inexpensive, reliable place where I would be able to take my 2003 Jaguar? I believe that my knock sensor has gone, and I have no mechanic experience myself. My car will not go over 3000 rpm and bucks while in the lower gears accelerating. Thanks in advance.
Check your local craigslist or the yellow pages for a mechanic that works on Jaguars/has a good understanding on how they work.
Call the dealer and see what they would charge to replace the sensor, so you have something to go by when checking out shops.
I wouldnt take it to just anyone who does it cheap.
macmar, just wondering, if you are fairly inexperienced with your car, what has lead you to believe you have a "knock sensor" problem. Has it been diagnosed? It sounds as if you are describing "limp" mode and it could be something as simple as a vacuum leak. Are you getting a CEL? Codes, if any, read?
The other interesting part of your post was you included the word "inexpensive' with good and reliable in your desired mechanic traits. Ah, to wish for all three...
I had received a code from advanced auto parts. The code read P0332 and P1111. I looked in the areas for a vacuum leak that were mentioned on this forum and I was unable to find anything. The "cruise not available" comes on when my car warms up and my car judders when I reach about 40-45mph. I don't know any other reasons why this would happen. Any input is greatly appreciated.
Calling Thermo
Thanks for the code. p0332 is knock sensor B low input. There are lots of checks for shorts and open circuits that can be done. Sounds up Thermo's alley.Hang in there, hopefully someone will be along with additional help. But, here's some info in the meantime:
P0332 G : DTC P0327, P0328, P0332, P0333, P1648. KNOCK SENSOR (KS)
G1 : CHECK THE KS SIGNAL WIRE FOR OPEN CIRCUIT
Yes Goto G2
No REPAIR the circuit. For additional information, refer to the wiring diagrams. CLEAR the DTCs. TEST the system for normal operation.
G2 : CHECK THE KS SIGNAL WIRE FOR SHORT TO BATTERY
Yes REPAIR the short to battery. For additional information, refer to the wiring diagrams. CLEAR the DTCs. TEST the system for normal operation.
No Goto G3
G3 : CHECK THE KS SIGNAL WIRE FOR A SHORT TO GROUND
Yes REPAIR the short to GROUND. For additional information, refer to the wiring diagrams. CLEAR the DTCs. TEST the system for normal operation.
No INSTALL a new KS. CLEAR DTCs. TEST the system for normal operation. If the DTC is repeated, INSTALL a new PCM. Before replacing a PCM, contact Dealer technical support.
G4 : CHECK THE KS GROUND CIRCUIT FOR OPEN CIRCUIT
Yes REPAIR the circuit between EN23, pin 2 (W) and GROUND. CLEAR the DTCs. TEST the system for normal operation.
This circuit includes the PCM. For additional information, refer to wiring diagrams.
No Goto G5
G5 : CHECK THE KS GROUND LEAD FOR OPEN CIRCUIT
Yes Goto G6
No REPAIR the circuit between EN23, pin2 (W) and EN16, pin 100 (BG). For additional information, refer to the wiring diagrams. CLEAR the DTCs. TEST the system for normal operation.
G6 : CHECK THE KS GROUND LEAD FOR SHORT TO BATTERY
No INSTALL a new KS. CLEAR the DTCs. TEST the system for normal operation. If the DTC is repeated, INSTALL a new PCM. Before replacing a PCM, contact Dealer technical support.
- Turn the ignition switch to the OFF position.
- Disconnect the KS sensor electrical connector EN23.
- Disconnect the PCM electrical connector EN16.
- Measure the resistance between EN23, pin 1 (N) and EN16, pin 98 (N). Is the resistance less than 5 ohms?
Yes Goto G2
- Turn the ignition switch to the ON position.
- Check for a voltage between EN23, pin 1 (N) and GROUND. Is a voltage present?
No Goto G3
- Measure the resistance between the KS sensor electrical connector EN23, pin 1 (N) and GROUND. Is the resistance less than 10,000 ohms?
- Measure the resistance between the KS electrical connector EN23 pin 2 (W) and GROUND. Is the resistance greater than 5 ohms?
No Goto G5
- Disconnect the KS electrical connector, EN23.
- Disconnect the PCM electrical connector, EN16.
- Measure the resistance between EN23, pin2 (W) and EN16, pin 100 (BG). Is the resistance less than 5 ohms?
Yes Goto G6
- Connect the KS sensor electrical connector EN23.
- Connect the PCM electrical connector EN16.
- Check for a voltage between EN23, pin 2 (W) and GROUND. Is the voltage greater than 1 volt?
FS[MidWest]: 08 XKR Convertible 59,XXX miles
MrNobody
08-27-2015 07:49 PM
