Chrome ( well plastic ) trim deterioration
Old 03-26-2018, 03:54 PM
Slownot's Avatar
Default Chrome ( well plastic ) trim deterioration
Trims around windows / doors gone dull and milky looking , anyone know a way of reviving or will it require a new set of ?
Old 03-26-2018, 04:57 PM
JBzXJ40's Avatar
You can try scratch/swirl remover or a light buffing compound, done this many times on other vehicles with chrome trim, works well.
Old 03-26-2018, 05:47 PM
Dell Gailey's Avatar
Small trim = Plast X would be a good place to start. After that, you could coat it with NXTv2.0 or whatever you like to use for wax.
Old 03-26-2018, 06:09 PM
On real chrome (metal) using aluminium foil and diet (yes diet not regular) coke is stupendous. Aluminum foil should be "crumpled" then back out to give it a "textured" surface when buffing. Aluminum foil is softer than chrome and won't mar the surface.
NotTheLotion
03-08-2014 07:21 AM
Jon89
06-19-2013 03:04 PM
aahmichael
06-21-2012 12:17 PM
Anticitizen
12-07-2011 06:11 AM
Jagman04
07-03-2010 02:38 AM
Quick Reply: Chrome ( well plastic ) trim deterioration
