Clicking AC Compressor
Old 08-07-2010 | 12:31 PM
Tony_H's Avatar
Default Clicking AC Compressor
The AC compressor on my 2003 was beginning to make a loud clicking noise when it was running. I added some AC lubricant and it has reduced the noise to an amost inaudible level. It seems there was insufficient lubrication to keep the compressor valves quiet.
Old 08-07-2010 | 02:59 PM
exrub's Avatar
What I've learned is that when the A/C clutch makes that clicking noise a lot, the refrigerant is low in the A/C system. In fact, I just paid close to a $1,000 to have my A/C compressor and other necessary parts replaced due to a leak in the compressor on my Mustang GT. Of course, it happened about a month after the extended warranty expired.
I would have the A/C system checked out. If this is the first time, you may want to have the system recharged and have dye put in so you'll see where it's leaking from next time.
Good Luck!
Old 08-07-2010 | 04:27 PM
Tony_H's Avatar
The clicking is not the clutch, it is a continuous clicking when the compressor is RUNNING. I did check the refrigerant in my system and it's fine. Aside from the noise the system works as it should. You can spend $1,000 if you like, I don't need to.
Old 08-07-2010 | 10:37 PM
exrub's Avatar
That's good. Hope your issue is something simple.
boiler
US Southwest
10-17-2015 10:35 PM
gunlocators
09-30-2015 09:05 AM
dan102877
09-29-2015 07:47 PM
Long Islander
09-27-2015 04:45 PM
