Clicking Noise Below - 2004 Xtype
![Unhappy](https://www.jaguarforums.com/forum/images/icons/icon9.gif)
Greetings all. I have not yet posted on my other XJ8 post yet as I've encounter issues with my daily driver. I have an issue that just showed up in the past day. At 50-70 it was making a very odd noise as well as almost a vibration. The vibration was so bad I couldnt go that fast had to keep it at 45. NOW a clicking noise is coming from below the car. Weird thing is you can only hear it when I am not stepping on the pedal. I have included a video where you can hear the noise happening throughout my parking garage while I am not on the gas plus some pictures + video of below. What you will notice in the video of below is the clicking seemingly happens when the car was sitting off just after I stopped. It would get quieter and each click farther apart the longer I waited. I cant tell if something is wrong with the Exhaust or with the Drive train therefore causing the weird vibration and noise. Also the exhaust is oddly curved down but maybe thats how its supposed to be, seems off. Please let me know what you think and link me the pages that have already been posted on this topic if there is any. Thank you ![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
Google Photos Shared Album
PS, I have no check engine light on so I can't just check codes. PSS, its not tires as they've been recently replaced along with the rims a week prior.
I hear what you are saying.....Bearings can be funny as they might only make a noise under certain load conditions, so effectively different when the engine is applying power through shaft rather than just freewheeling.
You might also find the bearing noise is different when accelerating versus decelerating as the bearing is under load but from the opposite direction.
That being said, you might also possibly have a U joint issue on the prop shaft, that when you have torque applied the U joint is held in position but unloaded it might be allowing some play to become evident. That too would throw the prop shaft out of balance as it might be rotating concentrically.
The transfer cases can also be a common weak point in the AWD models, generally making a increasing whine as they age, or if really bad a grinding sound. But that is less likely a source of vibration unless the output shaft has developed significant play.
Hi Dell, your right...sorry Vegang....(the curse of looking at these things during a short break at work, I only got to play the 1st clip).
That sounds curiously a lot like some heat expansion or contraction within the exhaust system as if it is loudest in the mid floor area of the car there are no valves or solenoids located there.
I am puzzled with the vibration at 50-70 Vegang is reporting......Dell, do you think he might have had a heat shield come loose?
That might now be vibrating with higher speeds and air currents under the hood and car and partially unsecured might be in contact with something an ticking as it heats or cools?
My first thought was the ubiquitous loose heat shield on X's. But, the continued clanking at rest had me stumped. And in the video it was rhythmic although the OP said later it changed as the car cooled. It almost sounded like a loose piece of a belt that slapped something but the repetition was too slow for that. I still sort of lean to a heat shield.
@vegang try post 10 & 11
https://www.jaguarforums.com/forum/x...ausing-253682/
SO I actually have some weird updates.
I sat under the car for about 30 mins yesterday and found a few odd things. Seems I have a small small oil leak not a huge deal I don't believe, but also seems I have a transmission leak as confirmed by a tech when i got an oil change the other day. I'm not sure if a trans leak could be whats going on as I haven't researched nor had one before so I'm just throwing that out there.
Some other things I noticed is about 4-5 bolts missing on various things under the car. The exhaust pipe hanger dead center of the car was not connected at all so I'm guessing that could be some of the noise I'm hearing. I also noticed a heat shield in the lower engine bay (have to see it under the car) had a bolt rusted through so it was really connected and I could move it with my hand. Plus a random cable that's not plugged in anywhere??
Even with both of these found I still don't believe they are the source of my sound/vibrations. Reason being is before I even checked under, the sound changed from the clanking you heard in the video to more of a belt noise. I only got one decent video of the new sound so I will upload to the same album Google photos shared album
Re your transmission leak, if you get under the car once the front is on ramps, you can easily tighten (gently snug) a lot of the small lower transmission bolts that are easy to reach. It's maybe a 10mm or even smaller, can't quite recall anymore. That helped my leaking transmission quite a bit from where it was sort of self-draining through the gasket onto the garage floor to no drips over the last month of just sitting without being driven.
@Dell Gailey @h2o2steam I could use a little guidance with the latest find. Took it to a local shop I trust and they claim the new wheels I put on from a year newer junked x type are not completely round. Weird thing is this issue happened around 4-5 days AFTER i got the new rims but they claim drive shaft is perfect and so on. Nothing wrong with car appartently. The clicking/thumping sound is so loud that I dont understand how that would come from the wheels. Just could use some input ![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
edit + the fact the first shop that put them on did not catch the error somehow...
I never got to update this post however I did resolve it kind of. Turns out the shop that changed my wheels & tires didn't notice the bolts needed to be switched to a different type and they started all backing off. I noticed one day while this problem was happening because I drove home and felt like my wheel was going to come off. Low and behold all 5 of the bolts where hand loose and about to pop off. Owner of shop drove to my place and tightened them all and noticed the issue and I got those replaced no issue since. HOWEVER something I am about to make a seperate post on is how I'm having a kind of fishtail issue happen that I BELIEVE to be tied to my lower driver side control arm.
If the "fishtail" feeling is when you power on a fairly lengthy sweeping on or off ramp (left or right) while applying power and it feels like the rear end is going to come around you (it won't) it's the rear upper control arms. Look up posts by member Thermo who pioneered the adjustable fix (Volvo parts). We call the fix Thermo'd.
Podelson
03-25-2022 01:09 PM
presidential27
04-15-2013 12:02 PM
