clutch flywheel problem please help
Hi Everyone
I have had problems with my car for the last few weeks. When in first gear as you leave clutch
the care vibrates from engine a bit. After clutch release again if i press on acelentor about
1200 to 1500rpm the car vibrates in first gear. It happens when car is warm not when cold. and
it does not occur in neutral. the idle is perfect 815rpm. theres no problem in engine no codes,
diagnostics test no problem is being detected. No misfifing. fuel pressure perfect, engine mounting
good. Cv Joints boot etc fine.
I feel theres is problem in clutch or flywheel. If there is this problem then
ofcourse I will have to replace the full kit.
I would like to ask how to test clutch and flywheel. In forth and fifth gear speed is normal.
sO i DONT KNOW IF THE PROBLEM IS THE CLUTCH.
Im confused as why it vibrates only in warm and not cold.
Can Anyone advice?
Also how much should it cost to replace clutch in the uk?
Thankyou
Can Anyone advice?
Thankyou
RoyLittle0
05-25-2023 02:38 AM
