Clutch Job = WOW!!!!
Old 12-19-2007, 11:56 PM
SpartanX's Avatar
Default RE: Clutch Job = WOW!!!!
Hmm, that seems a bit odd to me. When the clutch was on its absolute last leg, it was impossible to stall it and I'd have the pedal nearly all the way out before it'd feel it engage. That was with a bad pressure plate, clutch, and flywheel.
It is opposite day or something???
Old 12-20-2007, 07:47 PM
aquill1's Avatar
Make sure you keep us updated on that sparty!
Old 12-22-2007, 06:12 AM
Chas944's Avatar
Agreed, either it sounds like some air in the system or does the clutch pedal have any mechanical adjustment?
I know on my Porsche it uses a turnbuckle adjustment from the pedal that inturn pushes on the clutch master cylinder piston. And when I changed clutches in it the pedal had to be adjusted.
Old 12-23-2007, 06:42 PM
aquill1's Avatar
hmmm...you try any of that sparty? Get bo's number I'm sure you could call him to figure out how to do what he did...
Old 12-23-2007, 10:12 PM
SpartanX's Avatar
ORIGINAL: aquill1
I took it back yesterday and he said there was probably air in the line. He was right, apparently. Now, it's not engaging near the floor anymore .
It should be broken in by now. It shifts sooooooooooooooo great!
  #28
Old 12-23-2007, 10:15 PM
aquill1's Avatar
I bet...did you ever get grinding or anything or hard to go into gear? Can't remember what it was doing before...
Old 12-23-2007, 10:18 PM
SpartanX's Avatar
ORIGINAL: aquill1
No grinding since the clutch job. Before I took it in after the clutch was installed, it was catching close the the floor.
Before the clutch was replaced, everything was fooooked. The tranny was the only part that survived the ordeal.
  #30
Old 12-24-2007, 09:39 AM
aquill1's Avatar
Thats what I'm saying, before you took it in what was it doing?
  #31
Old 12-24-2007, 06:05 PM
SpartanX's Avatar
ORIGINAL: aquill1
It was slipping, and it was slipping some kinda bad. I could barely get the car to move in order to get it to the shop.
  #32
Old 12-25-2007, 08:05 PM
aquill1's Avatar
Was it hard to get into gear?
  #33
Old 12-26-2007, 06:48 AM
SpartanX's Avatar
ORIGINAL: aquill1
Actually, No. It went in to gear just fine. However, I had to slip it in order to get the car moving.
  #34
Old 12-26-2007, 06:54 PM
aquill1's Avatar
That sucks...
  #35
Old 12-27-2007, 03:04 AM
1600 bucks! yikes... I remember when i got a clutch job on my camaro was 800 bucks. Granted its like comparing apples to oranges. Igot a spec stage 3clutch for 300 bones and 500 labor. I just resurfaced my flywheel and pressure plate.
  #36
Old 12-27-2007, 07:18 AM
Received 9,010 Likes on 4,113 Posts
Nice one Spartan.......all sorted now mate and good as gold!
Jim
adam699
10-13-2015 05:53 PM
Nic1635
10-02-2015 01:30 AM
Johncy2000
10-02-2015 01:05 AM
Lawrence
XJ40 ( XJ81 )
10-01-2015 08:36 AM
millertic
09-30-2015 08:11 PM
Quick Reply: Clutch Job = WOW!!!!
