Code 1643 solved
Code 1643 solved
Had a 1643 thrown in the rain the other day....TCM fault, thanks to you all I was able to find out how to fix, I pulled the scuttle cover and wipers, replaced the cab filter (old one may be the oe from the factory) as I can no longer slide under the dash and figured it was a water leak opened the windows and hatch to dry out the inside...Just checked and after removing code took it for a short run...all is good...thanks for the help
morethansamson
07-02-2010 03:49 PM
