Code p0037
Hi
i have a 2003 2.1 x type and i have the code p0037 coming up on my code reader i have changed the down stream lambda sensor and reset the codes but the dash light as come back on and its still reading p0037 does anybody have any ideas what it could be. I have read on the net it could be a relay. Any help would be gratefull
kelv
kelv
hi
kelv
kelv
You have 4 sensors; two in front of and two after each catalytic convertor.
The first think to check for that "heater low" error is the fuse for the upper sensor; someone will chime in shortly with the fuse number (in the fuse box under the bonnet).
The heater elements will stretch as they grow older, sometime sagging far enough to contact the case internally; that will waffle the fuse in short order.
Eventually, the heater element will break like a light-bulb filament, which does mean that the sensor needs replacing.
Also, make sure your replacement is the Denso; other brands (Bosch, for example) have a different heater resistance and may show bad even though they are not.
philwarner
25
06-26-2021 05:43 AM
