Code p0417 2003 Jaguar x-type
I have checked for vacuum leaks, IM O-rings replaced, breather is new ribbed, vacuum brake line checked, MAF sprayed w/ maf cleaner. CEL comes on after 5 minutes(later in mornings. Car will run fine if I reset with obd II , until I turn ignition off, I will then have to repeat process. I think it goes into limp mode while CEL on, hesitates at 2500 rpm. I bought the car new, has 99,700 miles, no issues till now. HELP!!! Code is p0174, not p0417, dyslexia flare up, can not edit title.
Last edited by therealest8guy; 02-17-2014 at 04:51 PM. Reason: wrong code should be p0174
Terrance Williams
08-26-2015 11:50 AM
