Code p1647
Old 09-27-2018, 09:08 AM
XTYPESEAN's Avatar
Default Code p1647
Good morning,
I am wondering if anyone else has had this problem?
I got a code of P1647 bank 2 upstream O2 and replaced it and cleared the code, then after about 3 miles the check engine light cam back on, and sure enough the same code reappeared.
Anu ideas of what it could be?
Thank you, Sean
Old 09-27-2018, 09:18 AM
iownme's Avatar
i think (but im not sure) they also have a fuse,
i seem to remember reading that fixed it for someone
Old 09-27-2018, 09:24 AM
iownme's Avatar
possibly F20 or F21
XTYPESEAN (09-27-2018)
Old 09-27-2018, 09:53 AM
avern1's Avatar
Received 1,319 Likes on 1,004 Posts
The fuses for the 02 sensors are fuse 38 bank A and fuse 42 bank B in the engine compartment fuse box
Old 09-27-2018, 10:13 AM
XTYPESEAN's Avatar
I just measured the ohms on the old sensor and it is reading
0 ohms. Does anyone know if that shows that the sensor is good?
Old 09-27-2018, 12:41 PM
XTYPESEAN's Avatar
I checked the fuse which is F42 for bank 2 and the fuse is good.
Old 09-27-2018, 03:57 PM
Dell Gailey's Avatar
First question is did you replace it with OEM or one of the troublesome eBay cheap ones?
Shade tree mechanic testing of O2 sensor =
Multimeter testing =
Old 09-28-2018, 07:23 AM
XTYPESEAN's Avatar
I am using a Denso sensor.
Do you know which terminal I should check for the voltage and ohms, as I do not have a manual.
Thank you.
Old 09-28-2018, 08:04 AM
iownme's Avatar
i believe the upstream sensors have a gray plug and the downstreams have a black plug.
Old 09-28-2018, 08:17 AM
XTYPESEAN's Avatar
Correct, I was just not sure which color wires in the terminal I am supposed to check the voltage and ohms on. On the upstream, sensor side am I supposed to check the ohms reading across the 2 black wires?
Old 09-28-2018, 10:20 AM
XTYPESEAN's Avatar
There are 4 wires on the upstream bank 2. 1 white, 1 blue and 2 black. Does anyone know on the sensor side which ones I am supposed to take the ohms reading on and which ones on the harness side that I am supposed to take the voltage reading on?
Thank you
Old 09-28-2018, 11:37 AM
You can check this by going to the "stickies" on the main page and downloading the workshop manual.
XTYPESEAN (09-28-2018)
Old 09-28-2018, 07:37 PM
dwclapp's Avatar
XTYPESEAN: This post has pdf wiring diagrams for our X-Types: https://www.jaguarforums.com/forum/x...4-25-a-152076/
Oxygen sensors are in Figure 03.1 - Engine Management System
Search for "H02 Sensor" (Jaguar's abbreviation for Heated Oxygen Sensor)
XTYPESEAN (10-04-2018)
Old 10-08-2018, 10:37 AM
XTYPESEAN's Avatar
Ok update. I worked on it this weekend and I have ohms readings on both upstream sensors of 1.2 I have power going to Bank 2 upstream. I attached a test light across the heater circuit wires and turned on the ignition and the test light lit up for a few seconds and then turned off. I hooked up the scanner and it is showing no voltage fluctuation reading for both upstream sensors. Erase code and it comes right back. Has anyone had this problem before. I am at a loss! Any help would be much appreciated. Thank you
Old 10-09-2018, 08:22 AM
XTYPESEAN's Avatar
PROBLEM SOLVED! I spending hours testing, I ran across an article online talking of fake Denso O2 sensors, and sure enough The first one I purchased off Amazon was a fake. Bought a new one at a local parts store last night and problem gone.
Old 10-09-2018, 12:12 PM
See post#7 :-) :-) :-)
XTYPESEAN (10-09-2018)
Old 10-09-2018, 12:23 PM
XTYPESEAN's Avatar
Got mine from Amazon, and it was advertised as a Denso, But goes to show even someone off amazon is scamming. lol
Old 10-09-2018, 09:08 PM
iownme's Avatar
i had a denso from ebay delivered today :@(
and it was not cheap!
Old 10-09-2018, 11:23 PM
On the Lexus forum but still applies of how to spot a fake Denso sensor (no part number ON the sensor = real, WITH a part number = fake) =
https://www.clublexus.com/forums/ls-...-can-tell.html
The #4 about the lead wire is interesting. This might be a major reason so many eBay and Amazon clones cause problems.
https://www.ebay.com/gds/Oxygen-sens...9223532/g.html
Old 10-10-2018, 06:28 AM
iownme's Avatar
thanks for that...i'll check mine!
Quick Reply: Code p1647
