Cold Air On Drivers Side by Feet?
I was out driving the car the last few days with the heat on high it has been cold up here. What I have noticed is a bit of a draft around my feet on the drivers side of the car. The passenger side is toasty warm but it gets alittle cool on the driver side. Any ideas as to what could be causing the cold air intrusion on the drivers side.
I try to set the temperature control so that the heat comes out at the lower region rather then just letting the climate control take over.
THANX
THANX
Due to the fact you have X-type, I don't think you have dual zone climate control. So if you are getting heat on one side and not the other, you may have faulty air discharge temp sensor on drivers side. Possible also that a blend door not moving to where it is supposed to. Maybe not enough flow through heater core so not enough heat reaching drivers side. Lots of possibilities. Hard to diagnose without being there for that one I am afraid.
