Common problems
Transfer case and differential being low on fluid.
Drive shaft bearing going out and making noise in the cold.
Defroster vents not fitting correct and rattling
Steering wheel cover becoming deformed
Rear calipers freezing up
Headlights breaking
Wheel sensors becoming rusted and causing faults
Blend door failing
speakers blowing
Headlights breaking
Blend door failing
speakers blowing
well I just picked one up cheap a 2002. the drivers door lock does not lock and once put in gear makes a sound like it is locking 3 or 4 times but the drivers door remains unlocked and the manual knob on the inside of the door handle stays in the locked position.
the water pump is leaking.
the hood shocks are worn out.
the car makes a beeping sound for the first 60 seconds while driving.
let me know if anyone knows the exact quick fix for the beeping and door locks. thanks...
Received 3,894 Likes
bgr, the water pump is a really easy thing to change out on this car. After doing it, you will wonder why you waited so long.
As for the door lock issue, it is the latch mechanism in the door that is binding up and not pulling the cable to move the door latch. So, you need to get in and clean up the door latch really good and then apply some lube to the latch to ensure everything moves easily.
As for the door lock issue, it is the latch mechanism in the door that is binding up and not pulling the cable to move the door latch. Sound clean up the door latch really good and then apply some lube to the latch to ensure everything moves easily.
Thermo... i lived in Rochester when i first moved to the U.S. I now live in PA during the week and go home to Oneonta NY for weekends. I'm about 3 hrs from Rochester now.
When the weather gets warmer i'll likely take a weekend trip to your neck of the woods.
T'would be nice to meet up with you.
Have a great time in NY and dress WARM...lol...Rochester gets very cold!
