Component Speakers Installation Complete!
ORIGINAL: racerx82
hey Cobra,
I want to replace the subwoofer in the factory Jag rear deck housing. Not really good with this speaker crap stuff..anyway, so do i measure the hole in the deck lid, or the speaker I'm pulling out to get the replacement size speaker ?
hey Cobra,
Cool...good info, thanks for the advice....I think i'm just gonna take it all out and put it up on e-bay....I already have a nice sub (infinity) that i mounted in the trunk last year. I wanted the factory sub to compliment my aftermarket system......but it just might be too much bass for me...
Hey cobra right after I posted on here about those speakers we got notification that our order was placed and missing half of the stuff we ordered because they didn't have it! As I said we bought 12 pairs of them (which they showed that was their quantity left) well they didn't have any and so now I won't be getting them! I also ordered a 1000w 2 ch amp from american pro which I've never heard of but they are all over online. My buddy works at cc and he bought 2 of there better 12's, a 6x9 set and a 6.5 component speaker set from polk. He paid 300 dollars for all of it the cost was over 700 msrp. I might check his stuff out and get a set of the components that cost 300 and he paid less than 100!
Hey racer do you have a picture of them and how would I install them in my car? I assume they have the amp built in?
IronCobra,
Looks good! Did you ever mount your 6.5's in the rear deck and build the box for them?
It has been a challenge to get good sound in this car. I have settled on Infinity Kappas in the front, Polk Momo's in the rear doors and a single low powered 10" mounted in the rear deck. The Polks actually came with ~3/4" mounting ring that savedme from having to make one. The 10" just fit in the deck using 3/4" ply. I did not have any luck with 3 different boxes in the trunk. I've got a nice flat signal down to ~ 25Hz but would really like to make the 6.5's work.
#31
Ok, here's the deal.
When I mounted and created a box for the 6.5s in the rear deck I could not eliminate all the rattles NOR could I get the sound I wanted into the cabin.
I created a 10" speaker box that mounts agains the back of the seat and bolts to the top of the deck to keep some moving. It sounds really good.
![](http://img524.imageshack.us/img524/1928/boixcu6.jpg)
#32
IronCobra,
Nice clean install, that’s where my amp is going to end up too. I haven’t cleaned up the wiring on mine till I get the sound/config I want...and ya, still have some rattles.
Is that a band pass box, or do you have the speaker firing up?
aquill1, I'll try if I can figure out how to post a picture. I hadn't thought about 6x9's...suppose you could make them fit...and there is a small amp for the sub. I was trying not to cut too much of the X. The mounting for the 10" uses the X factory bolts on the rear deck and only required drilling 1 hole.
gotti15,I have the base system and you can add a sub using a line converter. Although my audible signal is flat to ~25 Hz, the X head unit CD player is capable of signals down to 20Hz, even with the line converter...Checked it with a test CD.
#33
Hey xtyperick where can you get a copy of a test cd at...I want a cd to test clarity and bass in a system for when people look at my product...I downloaded from here http://www.bcae1.com/ it has a file for audio testing but not what I was looking for!
#34
aquill1,
I use this but I'm sure there are otheres out there.
http://www.stereophile.com//reference/176/index.html
I've had it for a while. I think you can get them from musicdirect.com or maybe amazon.
Not crazy about the music on it but it really helps in setting up a system.
#36
#37
#40
