compression test
I have now got a test gauge to check my compression. The plugs out of the suspect back were full of carbon. I have disconnected the fuel pump before I start and have read I need to disable to leads that go to the coil pack, where do I need to unplug these from I can't seem to find the end?
Received 3,898 Likes
Chris, what you are wanting to do is install a jumper wire (with a built in switch) between the battery terminal of the starter and the small terminal on the starter that engages the solenoid on the starter. By flipping the switch, this will cause the starter to engage and roll the motor, but not activate any of the fuel system and/or the spark plugs. That way you are in complete control of what the motor is doing. Just make sure to use a switch capable of handling say 10 amps. Getting one that spring returns to the off position is a nice thing to have too.
Jaguar Forums Editor
Jaguar Press release
09-25-2015 11:58 AM
