Console light is what? 2002 X Type
OK, I've been through the manual 3 times and I must be blind because there is a light mounted on what looks something like a micr. or air duct shield on top of the center console behind the shifter. That light comes on and blinks. After I drive it a while it goes off. I cannot find what the function is and what the slotted piece it's attached to does. It's probably there but I can't find it. Is this the low battery light? I'm lost. thanks.
That is the coin holder and the red light is simply the alarm/security indicator. When you lock the car that light will begin to flash; when you unlock it is should stop flashing. If that red light flashes while you are in the car then there is a defect somewhere in the system - most likely something very minor - for example a sticking gate in the ignition switch - when you remove the key a small gate falls - you should hear it click when you remove the key. I would begin by thoroughly lubricating the ignition switch and all of the door lock mechanisms (the security system takes its signal from those lock mechanisms).
akejama (03-12-2015)
Sounds like fun but you are talking about a totally different model of Jaguar. There are no supercharged X-Types, and the light in question is simply the security system flasher.
Norseman02 (03-12-2015)
Hey thanks for the info. I knew it would be something blatantly obvious but I'm willing to feel stupid to resolve an issue before I get a load of costly grief. We've had 3 or 4 weeks of sub-zero weather and I think maybe some moisture frozen in one of the locks may have been the issue. I cleaned, oiled, and the light is gone. I appreciate you taking time to respond. While true this car doesn't have a turbo assist I will now refer to the security light as my Turbo Light. It sounds so much more classier. **grin** I love ya all and once again thanks for making my Jaguar experience a little easier.
Tom
Tom
Ok I get it-you are humor handicapped. Regarding your response of "no supercharged X-types" I have to disagree. Otherwise I have had something else that looks a great deal like a supercharger re-belted and upgraded with different pulleys.
Thanks anyway for the useful info.
