Coolant Leak 😠🤔😳
Coolant Leak 😠🤔😳
Hi Brains Trust 😊
have a coolant leaking issue on My X Type...
- Seems to be coming from the bottom the thermostat hose that hooks up to the oil cooler..
- Can someone please give me the name of the hose that's on the bottom... looks silver to me..
- Please find attached pic 📸
- A big thanks in advance that can help me out here...
- Mike
Bottom hose that looks silver
That part is the 'oil cooler outlet pipe' - C2S30225. There is a technical bulletin relating to that additional hose clamp you see where it attaches to the thermostat to prevent the hose from coming loose - XT303-S939 (jagrepair.com).
A cheaper option that I'm trying to source is just replacing the individual hoses on that pipe as the aluminium section should still be perfectly fine to reuse. Jaguar do sell the larger hose that connects to the thermostat - C2S40953, but I cannot find any information on the smaller hose that connects to the oil cooler as it has a smaller ID.
That part is the 'oil cooler outlet pipe' - C2S30225. There is a technical bulletin relating to that additional hose clamp you see where it attaches to the thermostat to prevent the hose from coming loose - XT303-S939 (jagrepair.com). A cheaper option that I'm trying to source is just replacing the individual hoses on that pipe as the aluminium section should still be perfectly fine to reuse. Jaguar do sell the larger hose that connects to the thermostat - C2S40953, but I cannot find any information on the smaller hose that connects to the oil cooler as it has a smaller ID.
had me baffled...
but will investigate 🔎 more into it ..
perhaps a pressure test may be in order??
thanks again for you help in identifying the hose etc...
Mike
Anglicomarine0326
05-31-2022 11:06 AM
jar
04-14-2012 05:05 PM
