Coolant level sensor
The X-Type does not have a coolant level sensor in the expansion tank. The expansion tank has visible coolant level lines imprinted on the tank.
If the cable you see near the tank is a 2 conductor plug and doesn't appear to have a home then it is the battery isolator connection that was used on the car when shipped from the factory.
You will find a nub at the bottom of the battery box. That is where that wire is plugged in. It is just a holder to keep it form floating around loose.
