Coolant reservoir nipple broke: can I fix with barbed brass fitting?
I noticed that my temp was fluctuating slightly. Popped the hood and found that the nipple on the top of the coolant res cracked. I can easily fix by removing it totally and threading in a barbed brass fitting of equal size.
Would anyone here see a problem doing that?
That's exactly what I did. I heated the brass fitting with a heat gun or you can use a propane torch. Just make sure you don't heat too much. Just enough that it slowly melts into the hole. Left it cool and connected the hose. I know that everyone says you have to buy a new tank but I thought I would try that first. Never had a leak since. Been almost a year.
Five Speed (06-10-2014)
KarimPA
09-12-2015 08:15 AM
OkieTim
09-08-2015 04:48 PM
KarimPA
09-03-2015 07:32 PM
