cooling fan continues to run after car is off
Angled needle nose pliers work just perfect
I had no Radiator fluid because the lip that connected the hose to the expansion tank was broken. So I changed the expansion tank myself. It is easier than fixing the hose.
I just happened to see this subject on my way to the XK8 forum and offer this although it might not be applicable to the X types.
The XK8 cooling fans normally run for a short period of time, + - 30 seconds, after shutting down. If the time period is much longer than that the problem is usually with the water pump which is a known problem in our models. The vanes of the OEM pumps are plastic which over time become brittle and disintegrate, thus no real cooling. If the fans continue to run long this may be the problem.
I should have added: If the water pump is the problem because the plastic vanes disintegrated, make sure the replacement pump has an aluminum impeller.
BrentGardner
28
04-26-2024 03:08 AM
SingBlueSilver
08-27-2015 02:20 PM
