Cooling system compacity
I am about to change out my antifreeze because of the leak on my thermostat housing seal. One question arises. How many liters of jaguar antifreeze i need to have correct 50/50 mixture. So if anyone can give me the answer greatly appreciated.
Juan
Miami. FL.
Juan
Miami. FL.
Received 3,905 Likes
Juan, the refill capacity of the system is 8.25 liters. So, if you buy 4 liters of coolant, you will be fine. The slight variation from a perfect 50/50 mix isn't that big of a deal. Worst case, you buy 5 liters of coolant and when you need to add any, you add in the straight coolant vice adding in water.
http://www.eetcorp.com/antifreeze/an...ze-faq.htm#q16
50/50 mix is good down to -34F.
Distilled water is way cheaper than antifreeze.
Why would you suggest 60/40?
trosty
26
12-18-2022 06:40 PM
