crank sensor
The position sensor is located at approximately 1 o'clock on the rear of the engine s you are looking at the engine. You will see an electrical connector plugged into the sensor. Once you remove the plug you will have access to the fastener holding it in place. Remove it and extract the sensor. Installation is the reverse.
