Cruise not available - found the issue
So my vacuum line going from the intake to the brake booster is leaking at the intake connection. I am currently shopping for a replacement online but my question is how to remove it without breaking something else? Is there a special tool I need or something?
Thanks!
Thanks!
Received 2,193 Likes
And there is a oring in there that leaks vacuum. You can get a replacement insert from jaguar, no need to replace the brass piece only the black plastic lock ring and oring. The leak on that pipe is usually at the check valve. You can fix this by puttng a 1" piece of heat shrink over the valve and shrinking it, OR just replace the whole pipe
I got my replacement hose from Amazon but it appears as if I need more parts still. For one the new hose does not stay in the UIM very well. After I drug the end over and plugged it in it still has a vacuum leak. What is this part called??
Also if you notice there is no 'brass piece' that some people told me to push on. Is that my problem? Am I simply missing a piece? Is this what I need?
Also what is this other hose that also plugs into the UIM and goes to a connector that is attached to the firewall? I have a leak there as well. I am having a hard time finding a good source that lists all of these parts and their part numbers.
And why the f can I not change my font sizes??
Jaguar Connector Kit, Vacuum Hose To Booster, X-Type, S-Type - JA-C2S-15816
chknhwk (12-08-2018)
Thank you! Appreciate it. I've found some online as well just not sure if I want to order them now or not. My gasket sealant trick didn't work either so now I'm looking to change all the o-rings and UIM gasket as well. It's too darn cold out to do it now so I most likely may have to wait until Spring...
Steve W
07-07-2017 05:26 PM
RSpi
02-25-2014 01:36 PM
Kevinhj
08-25-2013 09:42 PM
flay
08-19-2013 01:18 PM
evinnie
01-28-2013 12:13 PM
