CV axle replacement HELP
I need to replace the front drivers side CV axle on my 2002 jaguar x-type, 120k, auto, nonsport. On the front of the jag we just replaced the control arms, hub bearings, spindles, tye rod bushings, and sway bar links. Carelessly tore the inner cv boot when putting it back together.
If I could ask:
Does the trans fluid need to be drained first?
Is there a shroud/gasket ring involved?
Are there any other special considerations?
Advice or experience would be grealty appreciated. Thanks, Mike
If I could ask:
jaguar1976 (02-28-2013)
The left side is easy. Just pop it out. You'll get some fluid leak out. Try to figure how much and replace it. There are some recent post on refilling fluid. Use the search tools. There are several threads on this topic.
If you have the JTIS it has detail procedure. I believe the download is a sticky at the top of this forum.
jaguar1976 (03-03-2013)
mikenmikena (08-02-2020)
Other signs: the most common is a clicking sound in tight turns, especially at slow speed. Worn rubber boots. Any rotational play in the axle or in and out play beyond a tiny bit.
Don't tackle the right side axle until you read thoroughly on it. I've done one and it's a pain.
RoyLittle0
05-25-2023 02:38 AM
KarimPA
09-12-2015 08:15 AM
KarimPA
09-03-2015 07:32 PM
