CV removal procedure
Greetings, I have a 2004 xtype and I'm a bit confused regarding the removal procedure for the cv drive shafts. I keep seeing a reference to not pull one of the shafts no more than 200 mm from the transfer case housing. How are you supposed to remove the whole cv drive shaft assembly from the car? I've read through the description below, but its not clear to me. Any clear pictures of the procedure out there
Ive removed a number of cv type drive shafts and usually its just a matter of a sharp pull is needed to get them out. What am I missing?
Thanks, Davud
http://www.fixya.com/cars/t4312160-replace_cv_axle_2002_jaguar_x_type#
Detach the wheel knuckle.
using special tools 307-443 RH Halfshaft splitter ,307-442 RH Halfshaft splitter handle
detach the halfshaft.
Remove the exhaust muffler inlet pipe.
Remove the halfshaft seal.
Remove the transfer case Y bracket retaining bolt.
To prevent damage to the transfer box internal seal,
make sure that the link shaft is not retracted further than
200 mm from the transfer box casing.
remove the halfshaft.
Attach special tools to the halfshaft.
Lever the special tools to displace the halfshaft.
Install the transfer case Y bracket retaining bolt.
Remove the halfshaft.
Use suitable protective covers to protect the barshaft.
Remove the halfshaft snap ring.
Thanks, Davud
Steve M (11-20-2018)
OK, Thank you. The point I was missing is you have to remove the transfer case to remove the right hand side (Passneger side for me) shaft that goes into the transfer case. It sounds like you can just replace the mid shaft and outer CV but have to look into how to separate the inner CV joint.
It sounds like the left side CV is typical. Just pull.
Thanks, David
Thanks, David
Received 2,190 Likes
![Exclamation](https://www.jaguarforums.com/forum/images/icons/icon4.gif)
I damaged my right front passenger side inner CV boot while replacing the control arms a couple of months ago. It was just a pin hole but it is really spewing some grease around. I have read all of the threads about the danger of pulling out the shaft that goes into the transfer case, but without the special tool to secure the shaft, I'm concerned it will be too difficult to do without moving it the 200mm. Has anyone come up with some pictures of doing this with the transmission in the car? I've seen the pics of the process with the transmission removed, but I'm still confused how to get it done. I've read about the pickle forks, but I want to know if anyone has been successful doing that, and what the process would be to use them.
Is there another way to remove the inner boot without pulling out the entire axle that someone could recommend?
diesellee
09-23-2011 01:50 PM
derby98
01-18-2009 09:22 AM
