Cylinder 5 misfire I made it worse!
Hi,
2002 X Type sport 2.5. I have had a check engine light and codes P0305 and P1316. Yesterday I replaced cylinder 5 spark plug and injector. The coil is a known good unit. Upon start up the engine revs about 1800 rpm, the throttle is unresponsive and the dash message center is flashing "engine system failure" "gearbox failure " and "DSC failure" . I double checked my work . There are no fuel leaks. The connector to the throttle actuator on the throttle body is brittle and may be making a poor or no connection. I will check this today. Am I on the right track? Any help greatly appreciated.
Ken
Ken
Fixed ! Thanks to help on this forum and this post CLICK HERE .
The throttle actuator connection was so disintegrated that it fit upside down. When I checked and saw that I had the green wire on top i knew that was the problem. I switched the wires and the Jag now runs as normal.
Thanks everyone.
Ken
Thanks everyone.
Ken
SimonRage
06-26-2020 09:57 AM
Dirkman
08-30-2012 06:53 PM
crittie7777
09-09-2009 04:07 PM
