Cylinder 6 Misfire
Cylinder 6 Misfire
Well I put a new battery in to see if the electrical issue would go away. I cleared the codes before putting in the battery for fresh start. Unfortunately even after fitting the battery I got a check engine light while driving and codes:P0306; P1314, and P1000.
I just hope the misfire in cylinder 6 is due to a faulty coil pack and not something more serious. Gonna book her in to get the cylinder 6 coil pack replaced as a first measure and see what happens. I won't drive her anymore - will trailer her to the repairer to avoid doing more damage.
The following 2 users liked this post by Dell Gailey:
AceVentura (11-19-2022),
h2o2steam (09-01-2022)
+1 for Dell's suggestion, get the suspect coil and spark plug to cylinder 2 where you can remove it easily.
I chased random cylinder misfires for a year (but only about 1k miles) before finding out they were all related to failing fuel pump. In the end I got 6 new coils and plugs and new wires and a new fuel pump. The road to get there was painful but the car runs great since then. My point is don't assume when the computer tells you there is a misfire on cylinder X that it is that simple that you can isolate cylinder X.
Clackavosticus (09-02-2022)
Regarding the fault possibly being the fuel pump - I think that is unlikely in my case as I reset the codes and got the SAME cylinder (6) misfiring again. If it was fuel related I would expect other cylinders to also be affected and not the same cylinder continually. I'll keep it in mind though as a remote possibility.
