Damage to undercarriage please help me
Ok so i took a piece of retread from a truck tire at about 75mph. Went under the car and ripped off the scoop for the transfer case. I can find that. But it also bent the bar/connector between the frame rails. The metal piece that the transfer case scoop sits upon, the one that ya need an extension to get past for oil changes. What is this called, is there a part number and most importantly will i be able to drive 1500 miles home? Thanks in advance
Received 3,932 Likes
Gmaxima, you should be good driving home. Once you get back here, if you don't mind a little bit of a drive, you can come down to my place and I am sure we can get it repaired. I live down in California, MD.
If a new tube needs to be made, I should have all the tools needed to get it done.
FS[SouthWest]: 19" Aquila Wheels with Tires
jorgef858
01-14-2016 11:32 AM
