Dash Air vents
Hi,
im facing something weird to me, i bought my x type two months ago . Yesterday trying turning On AC but i conclude the two vents left(Driver) and (Right) vents doesn't blow air ! The middle console one's works perfectly, so im confused what would be the problem ? Anyone help me . Thanks
Jaguar X type 2005, 2.1 Petrol v6
Were those two vents working before or did you just notice it now? When you change the flow of the air (floor, defrost, etc.) does it work? Could be an issue with the blend door. Very common problem. Do a search on here and you will find out all about it.
If the flow of air moves where you direct it could it be that you simply have those vents turned off? I know that sounds very
basic, but sometimes the the simplest solution gets overlooked.
