Dash going dead
Guest
Posts: n/a
I got a 2004 x-type 3.0l with 50000 mi. and its gone nuts! The power train light come on at first then the car shifts down to a lower gear, the dash gauges stop working all except the gas gauge. I pulled the trouble codes out and it gives me a P1642,P1796. Has anyone seen this before thanks. I got the 2 front wheel bearing changed the other day and they aligned all 4 wheels. Picture of the dash as it was acting up on the road attached below. Also when this happend i stoped on the side of the road and shut the car off, restarted the car and i could not get it out of park. Re-cycled the key and started the car but that time i could get it out of park. Could it be a relay somewhere.
P1642 EMS
OBD II
CAN circuit malfunction Ignition ON 10 seconds 2 A ECM Default:
– Speed control inhibited
– Maximum throttle opening for
N range inhibited
– Throttle opening limited to
30%
– Maximum engine speed
reduced
EN16
-123
-124
CAN short circuit fault
Control module failure –
check for additional flagged DTC(s) to locate
control module source
P1796 TRANS
OBD II
CAN network malfunction Ignition ON – 5 seconds 2 A TCM Default
– Fixed 4th gear
JB131
-012
-013
CAN open circuit fault
TCM failure
[IMG]local://upfiles/2999/8BDC4FB34912474987019598009A559C.jpg[/IMG]
P1642 EMS
OBD II
N range inhibited
30%
reduced
EN16
-123
-124
P1796 TRANS
OBD II
– Fixed 4th gear
JB131
-012
-013
TCM failure
Received 3,901 Likes
Guest
Posts: n/a
Update on my problem.
The car is not acting up today. The first day we have had without rain! What i have done to the car I removed the TCM module to inspect it and the module was good and dry with no corrosion. I put a plastic zip lock bag over it and re-installed just to be on the safe side. Second i unpluged the 2 plugs going to the transmission to inspect and no sign of water and the connectors are in good shape, So got the tube out of dielectric grease and put some all over the plug terminals, pluged everything back and hope for the best! The rest of the week it's going to rain so it should be a good test.
Fletch44
09-28-2015 02:21 PM
