dashboard noise
![Unhappy](https://www.jaguarforums.com/forum/images/icons/icon9.gif)
greetings all...new x-type owner 55 plate 3.0 manual with 30,000 on the clock, was a proud owner but not so sure after reading through some of the threads in these forums.. thought i couldnt go wrong when buying a jag even if it is second hand but i cant believe the problems x-type owners have had specially machanicaly with transfer cases/boxes going on them in particular..amongst lots of other things so now not so sure if i done the right thing...ok my first query is to do with the dashboard dials i understand that when you turn off ignition as the dials settle to the bottom they make a wierd scratching sort of sound similar to a hard drive working away in a computer and jump for a sec thats fine but mine make this annoying noise all the time you rev the engine and the dials are coming back to the bottom, cant really be heard whilst driving but so annoying when slow moving or parking... does anyone have or know of the same problem and any ideas of how to cure it... many thanks in advance
Received 9,009 Likes
baskervillema
10-01-2015 06:43 PM
