Daytime Running Lights
Wondering if there was a way to run automatic daytime running lights. Doesn't seem like there's a good place to install any of those LED bar type running lights. Figured maybe someone came up with a way to convert the parking lights to running lights or something. I just want some running lights because I think they are safer and they look cool but it's not that big of a deal, I turn on the headlights sometimes when it's overcast or early in the morning. Just wish there was a way to have DRL's automatically turn on when the car's on. I think there might be a way to run a fuse from the fuse box to power on when the car's running but not sure how complicated that is a on a Jaguar.
Something like this?
DRL Relay DRL Module Daylight Running Lights Best Product on Market | eBay
They do make them, some are good just for LEDs and others for halogens as well...I have though about it too for my fog lights as DRLs since I pretty much never use them
Yes thank you. That is what I would need. Seems a little bit complicated with all the wiring but I guess if I really wanted them it's possible. Maybe a project for a rainy day. Also found this one with longer wires:
USA Made Truck Lite 97308 Heavy Duty Daytime Running Lights DRL Module Universal | eBay
X2004 (02-06-2014)
bracester (02-04-2014)
Received 3,887 Likes
04xtype04, keep in mind that there are 4 different headlight switches for the X-Type. They all control the headlights different ways. How do you want the headlights to respond? What I mean by this is that the American (non-DRL) act just like you are used to in that they only turn on the low beams when in the ON position. Where you have the Canadian switch which has the low beams on all the time regardless of the headlight switch position. Then you have the Scandinavian version which allows the low beams to be on with the headlight switch in the OFF position and ON position, but goes to only running lights in the PARK position (this is needed for some people that enter through guard houses and are required to dim their headlights, especially true of military bases). It seems to me that there is another switch which is like the Canadian switch, but it also turns on all the running lights too. So, what are you after?
Oh ya all in good fun my friend. I didn't realize that it could be enabled rather than aftermarket....im not one for DRLs anyway
What most cars with DRL's have around here are the high beams run at 30% power during the day, then when you flip on the headlights at night, the low beams turn on and the high beams turn off and go back to being normal high beam lights. I would probably just do this, although I was hoping for an LED route. Not sure if you can use LED bulbs in the high beams with reduced power as DRLs. Also the problem is LED's aren't bright enough to function as real high beams if I ever needed them. I guess I would probably want my parking lights in the high beams to be my DRL's and just run some bright LED bulbs in it. I'm am ok at wiring, took an electronics class before and have a soldering iron, just not too familiar with the wiring on the x-type.
These are the highest quality ones I have seen and used and inexpensive
Alright cool. I have similar ones like that on the way, can't comment on the quality of them yet but they are the 5-smd 5050 bulbs. I got like 10 for $5 so I decided to do it. Was looking at the 9-smd bulbs but I think a pair of those ran $5 so I decided I would try out the 5-smd bulbs first since the side markers and license plate also use that size bulb. We'll see how they turn out. I'm also waiting on some bulbs for the brake lights, just ordered those a couple days ago but they should be sick. Probably want to do the rear blinkers too in a bright yellow next just cuz I like LED lights.
