Diagnose this knock tic sound?
What is causing this?
I thick the tap sound is the tensioner
but there is also a tick sound from the rappers but I don't think you can here that in the video,
what would cause the tick?
I was thinking the exhaust manifold is causing that sound?
I know pulleys make some sound but it's the tick and tap sound that's annoying
https://m.youtube.com/watch?v=_gwMG1fgdPw
I was thinking the tap sound is either the main tensioner or crank pulley
the tension on the belt doesn't seem bad when the car is off but should i change it anyway?
the tap sound goes when you pick up speed
should I replace the crank pulley just in case?
it's an awkward job as ill be on my back doing it as soon as the weather drys
car5car
02-07-2016 12:51 PM
