Dice install 2007 xk
Yes, Antenna adaptor is required. sometimes it happens that it may not come with the kit you bought but its necessary so buy separately.
For the procedure,
first remove the battery cable connections and then remove out radio from the car.
Set the DIP switches for the frequency selector switch to the desired setting.
Install RDS cable and then plug in the radio antenna to the module receptacle.
Then put the radio in its place and connect the battery cable.
Set the frequency on the radio you want
For the procedure,
Thank you!
Any idea on the type of antenna adapter. I have looked at a number of sites and no one ( that I could find ) lists any adapter for the jag.. I can believe that they used a standard connector. I'm just trying to get everything in place before I take the console apart.
Thanks for the help!
Received 6,324 Likes
FS[LowerAtlantic]: 2007 S-Type $.2 For Sale
captbob73
10-24-2015 05:49 PM
'05 Gold XJ8L VDP
09-18-2015 07:15 AM
FS[SouthEast]: 2006 and 2007 Jaguar Media Press Kits
SCMike
09-09-2015 09:30 AM
