Disable rain sensor
motorcarman (04-30-2017)
I have a feeling that that the stalk is working correctly, but you find it frustrating to use as it doesn't seem to wipe when you think it should wipe. The stalk takes some getting used to and the intermittent feature can be varied to between 1 second and 22 seconds. Could that be part of it? Maybe check in the owner's manual on the operation as I remember it isn't exactly the most intuitive design.
Or do you mean that when it rains you cannot get the wipers to work intermittently at all and that they work continuously? If that is the case, then as the other poster said, just run them manually.
The handbook states that "the wiper lever must be in position 1 and Auto selected on the collar to enable automatic operation of the wipers".
The collar alters the wipers intermittent speed so rotate clockwise fully to be set at position 1. The lever should be set to OFF for the auto function to work. Simple really.
Roger
Roger
non functioning intermittant wipers
I know how the intermittent function is supposed to work,I have a toyota with that function
The original stalk does not have an "AUTO" position
I replaced the stalk from a working vehicle- No different
I replace the ECU and GEM modules and it still does not operate in the intermittent mode
Any other suggestions?
Or.....the windshield may have been replaced without proper sensor or correct connection?
Nephew had truck windshield replaced and auto quit working, he took it back and they had installed a replacement without the proper sensor. Smfh, lol. He questioned their professionalism and how/why that could be accomplished by a company that does nothing but auto glass.
