Disabling x-type auto lock feature FAQ
![Smile](https://www.jaguarforums.com/forum/images/icons/icon7.gif)
The X has a feature I read about in the handbook. If U unlock the doors with the FOB they will automatically relock about 45 seconds later,IF YOU DO NOT OPEN ANY DOOR OR TRUNK LID, If you open the doors or lid the feature is cancelled out until the next time you unlock it. I had this feature on my Benz and liked it. But the handbook said this feature is not enabled at the factory and to see your dealer. Does anyone know how to engage this feature? As I called the dealer and of course they want at least $105 to do this, that is 1 hour labor around here. Thanks
+1 on the how to auto lock after 45 secs. I sometimes forget to lock the car, and when your 7 feet away, the key fob is too far to work!
Also would like to know how to program the Auto Up/Auto Down windows from the key fob as well, if anyone can give us an insight. I know if you put the key in and hold it in the lock position they will close.
The auto lock feature only works when the doors are already locked and you do not open the doors or lid, as I said it a 45 second cycle. It does not auto lock the doors when you get out and close them. Only way to lock the doors then is to use the FOB or key.
The auto up and down is programmed with the buttons on the drivers door. you close the window hold the button up for 2 seconds, let go of button for two seconds and then pull up button for 2 more seconds. This should activate the auto up and down. When I had a new battery installed, this was the way the handbook said to do it and it worked.
Another nice feature I had on a Benz was if you had all the windows closed, you pressed the unlock button on the FOB and held it down and the windows will open. If they are opened you pressed the lock button and hold and they closed. No such function on the X.
Thats exactly what I wanted to be done, with the key fob up and down. I heard you can have the feature on the X, but must be programed by the dealer. Any Techs want to help out?
Ps: Do you have a owner's manual? It explains most of the features available or on the car.
To the best of my knowledge and also I just tried it you cannot lower or raise the window with the key. You can however have the 45 second lock and unlock if the doors and lid remain closed. programmed by your dealer, but it is a hour labor. I did a search on Google and could not find anything about how to program the 45 second feature. ![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
My X5 has the auto open windows and auto close on the fob, nice feature on a really hot day.
#30
#31
While we are on the subject of locks and windows. My right rear window won't auto open and close on the driver's door. On the door itself press the button and auto up and down works. Before I had my battery changed last fall all the windows worked with auto up/down from the driver's control panel. I had to reset all the windows and they work as they should, except for one. I tested the fuse boxes and there OK, So I assume it is the switch? How do you get off the plate that holds the 4 window controls on the driver's door. I have tried resetting it from the drivers door and from the rear door but nothing happens wit the driver's button, but as I said at the rear door itself the auto up/down works fine. Any ideas
#32
#33
![Cool](https://www.jaguarforums.com/forum/images/icons/icon6.gif)
While we are on the subject of locks and windows. My right rear window won't auto open and close on the driver's door. On the door itself press the button and auto up and down works. Before I had my battery changed last fall all the windows worked with auto up/down from the driver's control panel. I had to reset all the windows and they work as they should, except for one. I tested the fuse boxes and there OK, So I assume it is the switch? How do you get off the plate that holds the 4 window controls on the driver's door. I have tried resetting it from the drivers door and from the rear door but nothing happens wit the driver's button, but as I said at the rear door itself the auto up/down works fine. Any ideas![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
#34
I know when I lock the car with the key in the door and hold it to the right all the windows and sunroof close, also activates the alarm, I am going to try and see if the reverse happens if I unlock and hold the key to the left.
#35
I don't have an answer to your question but I know what you're saying about your problem. I have the same thing happening on my '03 but it only happens occasionally. Usually they all work then out of the blue one or more windows will not 1 touch from the master panel but will work from the individual door switch. Drives me crazy, but I've learned to live with my cars moods. Right now today all windows are working properly from the master switch.
#36
#37
Dont like bringing old post back but I was reading on the auto lock stuff and saw that a few on here are wondering about the Window up/down funtion from the key fob. I'm not sure if you can do this on a X-Type or not, but in the S-Type forum Stickies I have a Hints, Tips, and Tricks thread that will explain how to set this feature up for the S-Type. Normally this is a dealer activated funtion. It works for the S-types, so perhaps it'll work for the X-types. Good Luck.
Edit: The link...
https://www.jaguarforums.com/forum/s...-tricks-61017/
Edit: The link...
#38
On my 04 x-type estate, lock car, hold down lock on fob, if any of the windows are down, the windows will go up. One touch up/down must be programmed before hand. Works everytime though.
I know 2 stage lock/unlock can also be activated on the fob, just hold down lock and unlock at same time till hazards flash.
#39
JFenley, thanks for a useful post and for answering the question that was asked. To you other guys...why do you have to take off on every permutation and combination of inane speculation about door locks? If you want to talk about something else start another thread with a clear heading.
#40
