DIY Oil Pan Gasket and Rod Bearing Replacement write-up "How To"
Old 03-12-2017, 02:42 PM
gkubrak's Avatar
Default DIY Oil Pan Gasket and Rod Bearing Replacement write-up "How To"
Well here it is, finally finished replacing all the rod bearings in my 3.0 Jaguar X-Type. I wrote up a nice procedure with everything you need for changing the bearings, oil pan gasket, as well as cleaning methods, tools and part numbers, as well as plenty of pics!
Total cost with parts and tools was about $225. Much cheaper alternative to replacing the entire engine. With the new bearings, I am proud to say the knocking noise has vanished!!
I must say this was the most involved repair I have attempted. Hopefully this gives other people the confidence to do the job themselves!
Thanks for all who posted in this thread:
https://www.jaguarforums.com/forum/x...ket-faq-11221/
It really helped me out when doing the job. Any feedback or comments are much appreciated !
A few notes: I ended up drilling a hole through the TC as well as removing the oil pickup tube from within the pan. Also, removing the front 3 spark plugs made it much easier to rotate the crankshaft for replacing the bearings. Check the cleaning and inspection section before finishing the job and replacing the oil pan.
See the PDF attachment below.
The following 7 users liked this post by gkubrak:
avern1 (03-12-2017), B. Marcelis (07-07-2017), b1mcp (03-12-2017), Bruce in North Dakota (03-13-2017), clyons (03-12-2017), Norri (03-12-2017), ThomasX (03-25-2019) and 2 others liked this post. (Show less...)
Old 03-12-2017, 03:15 PM
Alfadude's Avatar
Wow! What a great write up. Thank you so much for taking the time to do that. I'm sure it will be a great help to anyone that.
Old 03-12-2017, 03:31 PM
Received 6,312 Likes on 5,499 Posts
Definately one for the "How To" section.
Old 03-12-2017, 04:34 PM
Lemons Racer's Avatar
That PDF is fantastic! I always thought it would be easier to replace the motor, but this may be a good option someday, hopefully far into the future lol.
Xerxes' Jag
10-26-2016 05:16 AM
ghiadon
10-17-2016 07:45 PM
Dennis Catone
10-05-2016 06:43 PM
benpearce2013
10-02-2016 08:06 AM
dubydogg
12-22-2006 08:55 PM
Quick Reply: DIY Oil Pan Gasket and Rod Bearing Replacement write-up "How To"
