Do the dealer drain the transfer case during regular maintenance?
I have a 2002 Jaguar x-type 3.0 L with 121,000 miles. I get regular service done to it, and was wondering if the dealer refills the fluids on the transfer case during regular maintenance. I have done ALL of the service checks at a jag dealer? thanks!
Nope and I would doubt they would. There is only a drain plug (no fill plug) so there is no way to check or top it off from factory. What you need is to install a oneway valve on the drain plug to pump in fluid. WildBill sells a kit, I bought it rather then trying to reinvent the wheel it works good but in reality if you're handy you can come up with the same set up at Home Depot for $50 or so.
Received 2,192 Likes
No, its not part of a regular scheduled maintenance schedule from Jaguar. (should be) I would do it and the drain and fill port are the same. You jack up the car about18-24" to the pinch mold from the ground (I don't remember but Ive posted it here before) and fill.
Its probobly in FAQ or sticky'd
aholbro1
08-05-2021 05:02 AM
