Door ajar light
It isn't a glitch, it is a sticky latch. Get a good spray lubricant (wd40 is not a lubricant) and liberally spray the latch on the door - close and open the door several times. Problem solved.
If at any time you find that the car will not lock, despite all the doors being closed, that problem is similar - it is a sticky "gate" in the ignition switch which is supposed to close when you remove the key, thus permitting locking of the car. Same treatment to cure.
dthompson7
04-19-2015 06:43 AM
