Door locks
Old 11-04-2007, 10:24 PM
justatoy's Avatar
Default Door locks
Ok guys, since your help worked last time I have another problem. The passanger side door lock does not work electrically. You can manually lock and unlock it but if you try to unlock it with the key fob or the drivers side you get nothing. Any ideas on this one?
Old 11-05-2007, 04:36 AM
Default RE: Door locks
had a similar issue on mine, needed a new latch to fix it. Think there may be a TSB to do with the issue.
Old 11-05-2007, 05:09 AM
Cadillac's Avatar
I think another FAQ coming soon on this issue .I think you've an earlier X model so most owners suffer from the key fobs as well
Old 11-05-2007, 09:50 AM
aquill1's Avatar
The key fobs have a tsb out on them...there was a problem with them and you have to have both keys to have them fixed...I'm pretty sure that for mine they had to replace an electronic piece in my rear passenger's door...the thing didn't work at all...good luck!
Old 11-05-2007, 10:19 PM
justatoy's Avatar
I think the latch issuse sounds like my problem. What is all involved in repairing this?
Old 11-06-2007, 08:46 AM
billinohio's Avatar
it's sounds like the door lock actuatror. have the same problem with my rear passenger lock. took apart to check, yep actuator. haven't replaced it yet. it looks to be a real pain. the dealer stocks these and there kinda expensive but if you have to have...
Old 11-08-2007, 11:40 AM
aquill1's Avatar
Pretty sure that is what my problem was but I can't remember as that was a year ago now...
99xk8guy
05-28-2024 09:36 PM
99xk8guy
06-05-2023 06:28 AM
kevinl
10-31-2019 06:15 PM
XJsc-guy
11-23-2015 01:56 PM
mrsimpson
09-15-2015 01:10 PM
Quick Reply: Door locks
