Door Panel
Door Panel
I have a situation with my driver side rear door panel...ITS LOOSSEEE, i checked the screws they all seem tight and secure and i even tried to re align it but out of ideas exept for taking it off and putting it back on...what is the procedure to mount the panel off and back on??? are there any illustrations or steps? I dont wanna wreck my panel In the mounting and unmounting procedure so if anybody can give me some pointers that would be great!!!
Received 3,927 Likes
jessy, you will need to remove the 3 screws that you tightened earlier (2 at the bottom of the door, 1 in the handle area). From there, you will need to slide a thin bar between the door panel and the metal structure of the door and pop out of place the 3 fasteners on the front and back edges of the trim piece (1 at the top, 1 in the middle, and 1 near the bottom at each end). now, pull the door trim towards you slightly and then release the pull cable going to the door latch (remove the cable from the retainer bracket and then bend the cable 90 degrees to allow the lead ball on the end of the cable to come free of its recess). Next pull the door panel out a little further and disconnect the power cable running across the back of the trim.
Installation is the reverse process.
jessy, just to let you know, the clips should be fairly standard clips and can be picked up at any local auto parts store. I know places like Checkers/Schucks/Kragens/Advance have a large selection of clips on the shelf. Just need a sample one to compare to what they have. Probably would save a few bucks too.
Received 9,011 Likes
The X type FAQ quick links are there for a reason guys....check it out
https://www.jaguarforums.com/m_4382/tm.htm
Jose
12-18-2021 08:16 AM
salP3082
09-25-2015 05:07 PM
