door projector lights/ puddle lights
You will probably need to "T" off of the dome light console, and run the wires down the A pillars, to the place where the speaker wiring enters the door. Shouldn't take but a few hours, if you are careful. Be sure to tie the wiring out of the way of all the window components.....Good Luck......Mike
mancjag (03-02-2016)
Thanks for your reply Mike. I think I'll have to take your advice and run a cable to interior. Was wishful thinking that there would be a spare connection in the door that I could use. I was just hoping all the looms are the same and all optional extras might have wiring at the door connector just obviously no wiring from that to the puddle lights/ power mirrors etc.
Make sure you check inside of the door first; I'd be suprised if the wire for the door light wasn't there.
Actually, rather than tapping off the dome light, simply tap off the courtesy light above the left-side footwell...which is where the factory tap is tied...on that side, and it's mate on the right for the right side door.
There is already a pass-through for wires between the wing and the door, you can run the wire in about a minute!
Thanks wa3ra Im going to take door cards off tomorrow so hopefully the wires are there. The rubber cable pass through between the doors are actually a plug and socket so can't actually get a cable through these ones unfortunately. Thats why Im really hoping the door looms are all the same and the wires will be there.
shaz
02-05-2016 10:12 AM
