Door wiring
Ok 05 x-type sport wagon. I want to wire the jaguar logo puddle lights but after purchase learned my car had the reflectors. I want to run wires through the door to the footwell light but I'm not sure how to get it from the door to the inside of the car. Skype tell me how to disconnect the wiring harness that enters the body?
Received 3,898 Likes
Vandyone, I tend to run aftermarket wiring for speakers into car doors. The best advice that I can tell you is to open the door fully and then remove the rubber boot covering the wire bundle at both ends. You can then use a long/thin screw driver with the wires taped to the end to push the wires through the rubber boot. Scrunching the boot to make it as short as possible tends to help too.
Just to ask the silly question, but have you checked to make sure that the wiring is not there already. Some members have found the wiring there near the puddle light/reflector and all they had to do was install a bulb.
When I want run the wire through some tight space, i used the thin stripe of metal from the old wind shield wiper (I kept a bunch of them, it hard but very flex, can bend around the curved conduit ) heat it red hot (if you don't heat it will break) and bend a small loop at the end then thread it through the crack, tie the wire to the loop and pull it back.
No wiring there. I'm more concerned with the plastic dial looking things. Idk if I'm to turn them and pull asks I'm cautious about tampering with them Because I'm afraid they will crack or something I want to make sure I can put everything back the way it was.
Jag4, I didn't do something like this on my jag, but I have done a lot of other vehicles. The big trick I have found is moving the boot around enough that you can get a straight shot through the boot. You get that done, the wiring is easy to pull. Re-seating the boot around the wiring is easy. Like I mentioned, using a long, slender screw driver or something similar is what I normally use and I tape the speaker wire to the end of the screw driver and push it through the boot till the end pokes out the other end of the boot. Then I remove the tape and pull the wire through after removing the screw driver.
Vandy, I can't help you there. My car had the door lights, so, I never had to play with them other than replacing a bulb.
