as dorii si eu codu de la casetofon la jaguar
salut...am schimbat bateria si mi sa resetat codul la casetofon la jaguar...ma puteti ajuta *** sa il aflu ? jaguar x-type 2002 motor 2500 V6 benzina...serie sasiu. SAJAC51M32XC83986 si Engine Number : 264741411XB ..va rog mult...Va multumesc
Welcome to the forum skriciu,
The language on the forum is ENGLISH please.
I've moved your question from Jaguar Forums Feedback & Suggestion Center to X-Type forum. This is the place to post technical questions about your model.
This is the decode for your VIN:
SAJ = World Manufacturing Identifier : Jaguar
A = Market & Airbag specification : Rest of the World
C = Transmission : AWD / RHD
51 = Body Code : X-Type 4 Door, High Series
M = Emission Type : ECS12
3 = Model Year : 2003
C83986 = Unique Production Number
As I understand it, you have disconnected the battery and need the radio security code. Is this correct? If so, any Jaguar Dealer can look up the security code for you from your VIN.
Please follow this link https://www.jaguarforums.com/forum/n...ntro-must-5/to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
hello ... I changed the battery and reset code to tape me to the jaguar ... can you help me how to find it? 2002 jaguar x-type V6 petrol engine ... 2500 series chassis. SAJAC51M32XC83986 and Engine Number: 264741411XB ..va beg ... Thank you
If it is the original radio in a European specification Jaguar then this may work
Enter any code 3 times so that the display shows "PLEASE WAIT"
Simultaneously press >> PTY A.MEM should only take 2 or 3 seconds and the radio turns on
Dacă este radioul original, într-o specificație europeană Jaguar atunci acest lucru ar putea lucra
Introduceți orice cod de 3 ori, astfel încât pe ecran se afișează "ASTEPTATI"
Simultan, apăsați >> PTY A.MEM ar trebui să ia numai 2 sau 3 secunde si radioul se aprinde
