Dot 5.1 brake fluid fine on 2010 X-Type?
I think I'll change my brake fluid soon, and Dot 4 Super seems to be recommended for the X-Type, I'm assuming Dot 5.1 would work fine too, but is it recommended/better?
Or is Dot 4 Super preferred for some reason?
I know Dot 5 is different, silicon based and not compatible, and not "mixable" with the others fluids so I'll be avoiding that.
I went to my local car shop today and I was a bit surprised that they had nothing except plain old fashioned Dot 4, so I ran away, and I'll go shopping online now, but just wondering if I should pick up a litre of Dot 4 Super or Dot 5.1?
Or will I just go with whichever is the cheapest?
I was going to do it the lazy way, and just suck the fluid from the reservoir, but I think I'll probably just do it properly.
Received 3,915 Likes
As far as I can gather 5.1 is generally compatible with other fluids, except for 5 (without the .1 at the end), but I don't know when 5.1 came out. Or if it was before 2011, when the workshop manual for the X-Type was released.
If that makes sense..?
Doesn't say anything about Super Dot 4 though..
Which is supposed to be what the X-Type needs.
Edit:
So it seems that Super Dot 4 has a higher spec than Dot 5.1, and is probably the way to go:
Edit:
Boiling Point:
- DOT 3 - 205°C (dry) / 140°C (wet)
- DOT 4 - 230°C (dry) / 155°C (wet)
- DOT 5 (silicone) - 260°C (dry) / 185°C (wet)
- DOT 5.1 (PAG) - 260°C (dry) / 185°C (wet)
- Super Dot4 - 300°C (dry) / 195°C (wet) - Racing Brake Fluid
I went with the Dot 4 instead of the Dot 5 since it has a lower viscosity.
It seems to have all the same specs, low viscosity, and similar boiling points to the Shell ESL.
I can't seem to find Shell Super Dot 4 ESL anywhere, it kind of seems like maybe they just dropped the "super" from the name or something.
I concluded DOT 4 Low Viscosity is what Jaguar Intended. DOT 5.1 is very close. Here's my research on brake fluid when I flushed the X-Type.
From the manual: Jaguar Super DOT 4 (ESA-M6C25-A).
The brake hydraulic fluid in the master cylinder and brake operating system uses non-mineral polyglycol based brake fluid
with a minimum standard of JAGUAR SUPER DOT 4. ONLY FLUID OF THIS TYPE AND STANDARD MAY BE USED.
Specs are confusing:
Looking further @ Viscosity:
Requirements @-40F
DOT 3 <1500
DOT 4 <1800
DOT 4, Class 6 <750
DOT 5.1 <900
Fluid Data Viscosity @-40F
Pentosin Super DOT 4 = 1500 (example of "Super" DOT 4 not having super low viscosity)
Pentosin DOT 4 LV = 700 (Meets ISO 4925 Class 6)
Shell Super DOT 4 = 675 (recommended - difficult to get in USA)
Bosch ESI6 = 685 (Best in USA? - very close to OEM recommended)
Motul 5.1 = 820 (Close to Level 6 and highest wet boiling point)
I used Bosch ESI6 - easily available in USA. Not sure what's available in Ireland, but any DOT 4 Level 6 (DOT 4 LV) should be almost identical to OEM.
Hope this helps!
- DOT 3,4,5 refer to fluid characteristics including boiling point
- Other characteristics include viscosity, which is covered by ISO 4925
- DOT 5 is silicon based and not compatible with X-Type
- DOT 3, DOT 4 and DOT 5.1 are glycol-ether based fluids and chemically compatible. (Traditional brake fluid & nasty for paint)
- Regarding "Super DOT 4":
- Unfortunately "Super" can be a marketing word (i.e. not all Super DOT 4 are equal)
- Sometimes "Super" refers to boiling point, sometimes viscosity. Jaguar intended the low viscosity version for the ABS to work well at low temps
- ISO 4925 Class 6 viscosity is the viscosity requirement (i.e. max 750 mm2/s)
- DOT 5.1 has higher boiling point than DOT 4
- DOT 4 Level 6 has lower viscosity than DOT 5.1 at very low temps
- DOT 5.1 has similar viscosity at normal temps and is OK to use and mixes with DOT 4
Requirements @-40F
DOT 3 <1500
DOT 4 <1800
DOT 4, Class 6 <750
DOT 5.1 <900
Hope this helps!
Yea, I came to the same conclusion too, after far too much research!
Although I was going by the Workshop Manual which only mentions the Shell Super DOT 4, I didn't even think to check the Owner's Manual which says:
Hydraulic fluid
The brake hydraulic fluid in the master cylinder and brake operating system uses Shell DOT4 ESL or a low viscosity DOT 4 brake fluid that meets ISO 4925 class 6 requirements.
I could have saved myself a bit of hassle by just reading this first, but I suppose doing the research and then having the knowledge is better than just blindly buying the correct fluid.
Hydraulic fluid
jahummer
76
04-13-2012 01:10 PM
