The dreaded "check engine" light.
Received 9,011 Likes
RE: The dreaded "check engine" light.
hehehe
and the winners are
P1316
P0171
P0174
P0306
P1111
2002 3.0 with 88K
issue is at mild/medium throttle levels, it seems like it hits fuel cut right at 3K RPM
if you just drive it nice and smooth its ok
or if its floored all the time its ok
had these codes before when i posted but just didnt post them..sorry hehe
and the winners are
P1316
P0171
P0174
P0306
P1111
2002 3.0 with 88K
You said u checked breather and IMT seals? How?
The lean codes are gonna be those things and also the little plastic booster hose. Goes from brake booster to intake manifold and has a check valve in it. If it is grey (the checkcalve) it is the old style.
Also the IMT seals, if you took them out to look at them, I hope you put new ones in. If they are yellow, they are old style. Green are new. If the breather hose is smooth, it is old. If it is shiney and ribbed looking, it is new.
These parts are all cheap. If they are the old style, change them.
ORIGINAL: FactoryJaguarTech
i havent checked the booster hose yet nor the intake manifold seals itself
i do have a set of those though, when i change the plugs out
all the other parts are the old style but no cracks yet
my cruise still works and everything else
in the summer the car is fine no nothing
as soon as cold weather sets in the light comes back
its like it a winter guest hehehe
Well if you are taking your intake off to do the plugs anyway, do your self a favor and get the two IMT seals and put them in. Also the breather hose and the brake booster to intake hose. Easy to do and cheap insurance to keep your car running well.
Oh...and before you go snapping the tube, to get the plastic lines out of the intake manifold, ie booster line, you press with a small screwdriver the outer black ring, as you push down on it, push the tube slightly and pull it back out. Many don't know how to get them out and end up snapping it inside the manifold. Then it can get ugly.
The two big valves on passenger side of intake manifold. You didnt answer, you said you checked them. How did you do that?
Also the hose from the booster. The grey valve in the middle, with car running wrap your hand around and see if noise changes.
o-rings where not cracked or cut anywhere
old looking yes, but all in tact
i havent checked the car yet due to work schedule and the wife has
the car when i am at home
That is probably the source of your rough running if they are hissing.
Those seals are probably 3 bucks each from the dealer. Just be careful putting on the lower one that you dont cut or tear the seal.
Slow and steady beats fast and furious eveytime.
