Driveline vibration
Old 03-09-2007, 12:50 PM
RudyF6's Avatar
Default Driveline vibration
2003 X-type with30,000 mi. on it- Dealer tells me it needs a driveshaft ***'y (that's on backorder) to fix a vibe that happens from about 55-75 mph. I figured as much, but what bothers me is the loaner I got was a 2007 with 7,000 miles that had exactly the same problem. Is a driveshaft replacementpart of routine maintenance, or what?
Advisor told me the complaint is more common when it's cold (great - bought awd for a winter car!).
Anybody else having this issue?
Old 03-09-2007, 01:15 PM
RudyF6's Avatar
Default RE: Driveline vibration
How long have you waited? Just yesterday I was told it may be 3 weeks.
Old 03-09-2007, 04:27 PM
racerx82's Avatar
Driveshaft is a problem, not because it's bad, but because there is a gasket between the flange and driveshaft. The gasket, over time, (heat, cold...etc) contract and expands quicker than the metal, one being steel and the other aluminum, causes the bolts to loosen up. This makes the driveshaft twist off center causing the vibration.
The fix is to replace the gasket, line up the shaft and torque the bolts back inplace.
Your driveshaft is being replaced because it must have been loose for quite some time and may have bent.
Old 03-09-2007, 06:36 PM
RudyF6's Avatar
Good info, Racer. Looks like a p.o.s. design, but we'll see how a new shaft goes. Might have to make checking bolt torque on the joint and center bearing bolts might be part of routine maintenance.
Old 03-11-2007, 10:37 PM
racerx82's Avatar
Personally I think it's a great design and a good thought process went into it. The gasket seperates the two metals...aluminum and steel with aluminum bolts.
If they used an aluminum drive shaft, there would be no worries....but they decided to make it out of steel for reliability the different metals don't like each other...lol...
You can check it yourself, green line should be lined up.....if not, loosen bolts, align, and re-torque...
Old 03-12-2007, 12:17 AM
Hey Guys,
I am going to have the dealer look at my car for similar problem. Seems like there is whining/vibration as well with my 03 Jag. When i take it in for 40K service, I will have them look at this along with other minor issues.
Old 03-12-2007, 12:27 AM
Racer,
By the way, how common is this? My warranty runs out in Jun 07. Should i get extended warranty? I don't want to be paying money out of pocket every year to fix something so costly???
Old 03-12-2007, 11:36 AM
racerx82's Avatar
Hi and welcome Pharmgirl,
your 05 should be fine as far as the driveshaft is concerned. All the bugs were worked out by the time the 05's rolled out off the assembly line so you don't have too much to worry about. As for the shimmy in the steering wheel at highway speed....I would get the tires balanced and rotated....
If you don't mind me asking, what you pay for it and how many miles on it?
Old 03-12-2007, 12:01 PM
bigdreams05's Avatar
Put it like this, if you get the extended warranty, you'll have peace of mind. If you don't and something happens(knock on wood), you'll be kicking yourself in your --- for not getting it!
Old 03-12-2007, 12:04 PM
racerx82's Avatar
lol, that's one way of putting it...lol
Old 03-12-2007, 02:21 PM
Racer,
Anymore research and answers.
I will look into an extended warranty thing. I like to keep the car as long as i can, and i sure don't want to spend more money on it for repairs.
Old 03-12-2007, 07:12 PM
racerx82's Avatar
It's a personal preferance....If you feel you need it get it...(can't hurt) I don't normally hold on to any of my car after the warranty runs out so I never get it...by the end of the 3 or 4th year, i'm boared with the car and end up getting new one with new warranty...lol i know it's cheesy...but hey....i can't take the money with me...and I'm not leaving it for the kids...lol
Old 03-12-2007, 09:43 PM
X2 Jag's Avatar
ORIGINAL: caspercollins
......I've had to have several smaller problems (ex:squeaky window) were easy and fairly inexpensive fixes.
[/align][/align]I always thought the squeaky window on my passenger side window was cause by the tint. What is the fix for that issue? [&:][/align]
Quick Reply: Driveline vibration
