driver side door help
my door on the drivers side is messed up. i cant open it through the inside so i have to lower the window through the outside. and occasionally i have to mess with the door handle through the outside then it will open. do you know what part i would need to fix?? n is it easy to fix? n how to fix it?
Thanx
Thanx
Seems to me that you have one of two situations going on with your door.
1: The wire going to your inside door handle has gotten frozen up and needs to be lubed
2: You have not lubed the actuator correctly (nobody has) and as a result, you burnt out your actuator motor.
Either way, you are going to have to remove your passenger side door panel and you may break a few clips in the process. (PM me if you need some, I sell them for $1 a clip +$3 shipping) To remove the door panel you will have to remove the two screws at the bottom of the door, and the screw in the center of the door which is covered by a circular plastic cover. Then you need to pull the door straight out to remove the clips from their mounts in the door frame. Once you get there, you will be able to see the lock actuator and the cable that runs from the actuator to the door handle on the inside (red tips on the cable.) Lube this cable, and see if that fixes your problem. If it doesn't, you are going to have to replace your actuator which is another 3 screws that hold it into the door and a couple of electrical connectors after you have removed the linkage from the actuator to the outside door handle. Let me know if you need any help, and if you need a new actuator, go to ebay or car-part.com
Received 9,010 Likes
99xk8guy
06-05-2023 06:28 AM
Dicque
09-19-2015 12:53 PM
