Drivers Door Handle
Greetings Everyone. Just when I had my 2002 X Type 3.0 running perfectly my bad luck strikes again. Now it seems the drivers door outside handle only works from time to time. Sometimes it takes two pulls to open, and at other times nothing. The handles does not even feel connected to anything. Next time, after one or two pull its fine again. I've read the other posts and think I am doomed. I'm sure I need to have someone remove the inner door panel, as I know if I attempt it, I will mess up the power switches etc. Any idea what the problem is, so I can budget for this extra expense? Also, on another note, with all of Your help my Jag is running and driving like new. Just turned 99,700 miles. Thanks, Mike.
I had exactly the same problem on my X Type. It was just a case of adjusting the linkage. My mate did it for me, he's a body guy. Just popped off the door panel and it only took a few seconds. Driver's door all good now, but recently the same thing has happened to the front passenger door!
Not sure if you fixed your issue but I had a similar one some time back and had to destroy the door panel and then grind the lock inside the door to get it open. What a nightmare.
Driver Door Won't Open At All! - Jaguar Forums - Jaguar Enthusiasts Forum]
