Drivers seat
My drivers seat up and down function quit working. When i push on the lever, you can here the motor working but it doesn't move the seat. Forward/backward, and the reclining one works fine, its just the up and down one that's not working. Anyone run into this problem before? What could be the problem and the fix?
Striker27...... Can you help me a little more? Where are they? Is it and easy fix? and did you have to replace anything...
I just have had this problem myself ... and since the motors is still running i caint seem to figure out whats going on ...
more information on this would be great! Thank you......
Their is a shaft that went from either side of my fore and aft motor under the seat. You can see the motors when you look under the seat. I had to replace a shaft that was like a tightly wound spring.Unfortunatelysomeone managed to stuff a cloth grocery bag under the seat and when they pulled it out it pulled out the spring. I ended up getting a new shaft for the motor instead of finding the one that was lost.
I went that route simply because it was cheaper to do that then replace the whole seat mechanism. You have to pull out the seat and take out the motor and reinsert the shaft took somewhere around 15 minutes for me.
Guest
Posts: n/a
both my front updown motors failed on my car. it was a plastic gear inside the motor that failed. I had to replace the motors.
You need to unbolt the seat (easy) to get easy access. Motors are easy to change, but sort of expensive.
maybe one of the techs here salvaged one from a seat replaced for some other reason???
Miles86XJ6
09-14-2015 01:08 PM
jagent
09-12-2015 09:10 AM
FS[Western US]: parting out 1999 xj8 vandenplas
bavareze
09-11-2015 01:49 AM
